EBL VE Learns - % Never Exceeds 10% ??
Old Jul 21, 2018 | 09:26 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Appears the highest VE Learn % I get is 10% yet when I capture the "learned" table I'll get another 10% in the same cells. This can happen multiple times. Why am I not getting 30-40% corrections on the initial learn? This normal?
Old Jul 21, 2018 | 11:25 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: EBL VE Learns - % Never Exceeds 10% ??
Assuming you are learning from long term fuel trims, BLMs it has to do with BLM limits and the total amount of fuel corrections.
Besides you would not want to make that big of a change at once. More learns with smaller adjustments will get you where you want to be more easily.
I made a spread sheet for the LS based PCMs I tune in Excel. I use 1/2 of the error value to drive the VE adjustments when the tune is far off and drop that to 1/4 of the error as the tune gets close. Sometimes a very minimal VE table change or MAF table change can make a relatively large change in fueling.
Old Jul 21, 2018 | 01:08 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Thanks for reply.
Learning from NBO2 - that looks at BLM trims to develop corrections?
So after 10% corrections are captured in a bin successive VE learns against the corrected bin of another 10% are not unusual? Roughly, when should I start to see the % come down?
And (sorry for all questions) Is there a point where I should factor the entire bin down like (for discussion) 30% (or whatever I'm getting in total) and restart learns?
louiethebats
Mar 16, 2014 09:22 AM
Damon
Jul 27, 2003 09:39 AM
Damon
Jul 14, 2003 04:58 PM
Damon
Jun 22, 2003 03:51 PM
ULTM8Z
Feb 13, 2003 07:23 PM
