Fuel Trim Question - EBL BLM INT
Old Aug 15, 2018 | 12:17 PM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Forced open loop by maxing CTS threshold - In doing so doesn't the ECM look just at the VE tables without any trimming?
Old Aug 16, 2018 | 08:22 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Re: Fuel Trim Question - EBL BLM INT
Fairly simple question. Got answer....
Old Aug 16, 2018 | 09:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Correct. Unless the power on init for the BLMs has been changed to other then 128. In that case the BLMs can be different then 128.
RBob.
Old Aug 17, 2018 | 08:38 AM
Cartrax's Avatar
Car: "84 Crossfire
Engine: 383 Stroker
Axle/Gears: 3.54
Thanks for the response. I know it was a dumb question but my data log made it look like something was leaning the AFR in open loop. I know now that it's the VE tables only and the VE's needed to be jacked up. Getting closer to a final tune each day now... steep learning curve and mechanical issues haven't helped.
Ronny
Mar 21, 2010 09:29 AM
87 Vette Owner
Jun 3, 2007 10:20 AM
Mastiff
Aug 22, 2004 06:13 PM
Craig Moates
Jul 30, 2002 02:32 PM
