Car won't start if I don't give it throttle...
Old Aug 14, 2018 | 08:29 PM
Kyler_89RS's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi
Hey everyone. My car won't start unless I give it gas. Once the engine is warm, 8/10 times, the engine will turn over no problem without the help of the throttle. This has been a problem for as long as I've had the car (over a year). Is there anything I can do to fix or at least help this issue? Any help is appreciated!
- Kyler
_________________________
1989 Camaro RS
Stock 305 TBI
90,000 miles
Old Aug 14, 2018 | 10:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Car won't start if I don't give it throttle...
Usually not starting without throttle opening at cranking means you either have too much fuel or not enough air. Could be the idle air control valve, throttle position sensor or a leaky injector.
Old Aug 14, 2018 | 11:28 PM
Schurkey's Avatar
What is the fuel pressure at idle?
Does the pump run for two seconds when you turn the key to "Run" but DON'T start the engine?
Old Aug 15, 2018 | 07:11 PM
Kyler_89RS's Avatar
Engine: 305 TBI
I don't know my fuel pressure by heart. I always let the pump run before I attempt to crank the car.
Old Aug 15, 2018 | 07:14 PM
Kyler_89RS's Avatar
Engine: 305 TBI
If it's too much fuel, how would I go about correcting that? Should I replace the intake to see what that does? The car idles at about 500-550. Is that a reasonable idle speed or should I increase it?
Old Aug 16, 2018 | 12:37 PM
Schurkey's Avatar
You don't need to have it memorized, but you ought to check the pressure due to the problems you're having. Good to know that the fuel pump relay is working.
What does replacing the intake have to do with "too much fuel"?
Is the O2 sensor showing a rich condition?
What is the commanded idle speed, and the actual idle speed?
Old Aug 21, 2018 | 10:10 PM
Kyler_89RS's Avatar
Engine: 305 TBI
If you read Tibo's reply, you would maybe understand why I said to replace the air filter/ intake.
Old Aug 22, 2018 | 10:32 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Oxygen sensor shouldn't affect startup as the oxygen sensor takes a minute or two to heat up via the exhaust. Only way an oxygen sensor is helpful at startup is if you have no start condition and the sensor is heated.
mb67
Aug 12, 2010 03:46 PM
Xx89CamaroRSxX
Mar 25, 2010 10:24 PM
fryer1979
Northern California
33
May 31, 2009 03:27 AM
fleahy
Oct 14, 2008 09:16 PM
transram88
Apr 5, 2005 05:52 AM
