305 tho runs great cold, rough idle, sometimes dies when warm
Old May 12, 2019 | 09:37 PM
FormulaBerny's Avatar
Car: 92 Firebird Formula WS6
Axle/Gears: 373, Im guessing
I have a 92 Firebird Formula with 305 Tbi. It starts and runs nice when cold, although does idle kind of high. After reaching operating temp it still runs good until it is shut off. Upon restarting it idles like crap, sometimes dies. After reving it a few times it seems to straighten out but it is getting worse. Is anyone familiar with this problem and if so where do I start, thanks.
Old May 12, 2019 | 10:59 PM
Schurkey's Avatar
Re: 305 tho runs great cold, rough idle, sometimes dies when warm
When was the last time you cleaned the throttle body and the idle air passage?
When was the last time you connected a scan tool and looked at the data stream?
Old May 13, 2019 | 06:18 AM
I havent done either of those things, I havent had the car for very long. Thanks for the ideas now I have a place to start
Old May 23, 2019 | 01:26 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Check the other thread where I explained how a bad fuel pump/inlet hose was the problem in my case.
Old May 25, 2019 | 06:14 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I had a similar problem, and it was the o2 sensor, but no code. When was the last time you replaced it? They gunk up with carbon over time.
Old May 26, 2019 | 08:08 AM
Did a Tbi rebuild and now it runs great
Old May 29, 2019 | 09:57 AM
King E's Avatar
can you tell me how you fixed the idling problem, my car turns on altho sometimes doesnt wanna crank anymore, once its on i have to keep it revved up so it doesnt turn back off. can you give me any ideas of what it might be?? by the way i have a 84 z28 camaro
Old May 29, 2019 | 10:38 AM
I just installed a Tbi rebuild kit from Napa, while the unit was apart cleaned it real well, cleaned iac, then went through the idle reset process and now everything seems good
Old May 29, 2019 | 11:20 AM
But I suppose your 84 Isnt a Tbi probably carb?
david068513
Apr 28, 2015 11:12 AM
Lck119
Oct 6, 2014 01:52 PM
Motown
Oct 9, 2011 09:10 AM
Irocz_89
Jun 10, 2011 06:47 PM
