Trouble starting when cold 305 TBI
Old Jul 18, 2019 | 07:20 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
The last couple of times I have had trouble with cold start. It will start with the familiar rev, but it doesn't stay running. The only way I am able to start it is to hold the throttle down like it's flooded. When It starts, it runs rough and very rich until it clears up, then it runs fine. I blow lots of gas out the exhaust. I thought the coil may be bad. I have new cap, rotor, wires, and distributor. Any ideas would be appreciated. This is a 92 TBI 305
Old Jul 19, 2019 | 04:57 PM
Schurkey's Avatar
Re: Trouble starting when cold 305 TBI
Connect a scan tool, look at the data stream. I'd be especially interested in coolant temp sensor, Idle air control, and short- and long-term fuel trims.
Wouldn't hurt to verify fuel pressure, too.
Old Jul 19, 2019 | 05:27 PM
I replaced the cts, and the starting issue is gone. Funny thing is I replaced it this early spring, so I put the old one back in and it works. still having trouble with temporarily stumbling after the engine is warm, and I start and drive. It goes away, but it's annoying. I can't figure that one either.
Old Jul 20, 2019 | 09:34 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check the connector for the CTS. Many times I've had to replace both at the same time due to corrosion on the connector pins/terminals.
RBob.
wayshegoes
Jul 17, 2022 03:43 AM
Nick Locking
Carburetors
Sep 8, 2016 06:54 PM
mene0013
Jun 23, 2014 08:27 AM
jbarboza19
May 1, 2012 07:59 PM
dono420
Nov 1, 2004 06:58 PM
