idling too high and having trouble starting in the cold
Old Jun 22, 2014 | 09:16 PM
mene0013's Avatar
My car has trouble starting in the cold or after sitting for some time. When the engine gets warm it idles too high. In park in idles at 1100-1300 RPM.
Anyone know what the problem might be?
thanks,
Roberto
mene0013's Avatar
Re: idling too high and having trouble starting in the cold
Car is an 88 GTA with the 5.7L which is stock.
Old Jun 23, 2014 | 08:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Did you check pull/your IAC (Idle Air Control ) valve and TPS (Throttle Positioning Sensor) Settings? The IAC gets pretty carbon-ed up.
Do a search on here for the setting procedure for all this and folLow it to a T.
Your IAC is most likely sticking
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
backtothe80s
Sep 5, 2015 12:39 AM
