Better TBI throttle Response?
Old Aug 15, 2019 | 07:14 PM
McLovin1181's Avatar
I have a 92 RS with the boat anchor 5.0L TBI.
I only autocross this car, but the engine is rather slow to respond to throttle inputs.
That slow response is really hurting my times as I have to gas it 1-2 seconds before I need power.
Is there a way to make it more snappy?
I know modifying 5.0L is a fools errand, but what can I do to make it less sluggish
I already rebuilt the TBI and injectors.
That helped a little but not much.
Old Aug 15, 2019 | 11:52 PM
Firebirdwade's Avatar
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: Better TBI throttle Response?
Exhaust, Throttle body spacer and injector pod spacer on as well as the "ultimate TBI mods". You can also put an adjustable fuel pressure regulator on the back of the throttle body.
https://www.thirdgen.org/ultimatetbi2/
Old Aug 15, 2019 | 11:58 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
What airfilter/intake system are you using?
Old Aug 16, 2019 | 02:18 PM
Schurkey's Avatar
Connect a scan tool, find out what is WRONG with that TBI system.
What is the fuel pressure?
What is the cranking compression pressure?
Having to apply gas pedal 1--2 seconds before the power arrives indicates a REAL PROBLEM to be fixed. Grinding the TBI casting and installing spacers is NOT the proper way to resolve this.
Old Aug 16, 2019 | 02:33 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Depends on what you are comparing it to. I'm guess he is moving almost instantly but doesn't feel the kick in the pants (well slap its a 305 lol) for 1.-2 seconds. But you have to remember 197HP on a push rod V8 that doesn't make even that power until about 2500 RPM's is going to feel sluggish if you are use to more modern cars instant power off the line... If this is the case I would think just squeezing more power out of it would help. If this isn't the case and it really ia 1-2 seconds before your moving then yea you got big issues somewhere.
That said if you still have factory injectors then the spray pattern is probably shot etc.
You also have to remember you probably have a 2.72ish gear in the diff, its geared for high way cruising not 0-30-5-40-20-10-60 mph rapid changes that auto cross can require.
Old Aug 17, 2019 | 12:07 AM
Engine: 383
Transmission: WCT5
Of course I was not making those suggestions as an alternative to correcting real problems with the TBI. Just sharing some modifications I have done to TBI systems after I am satisfied they are running properly to maximum stock potential.
Old Aug 17, 2019 | 08:35 AM
Sweatlock's Avatar
Interesting point about comparing to modern vehicles with drive-by-wire throttle systems - those things seem waaaay too sensitive to me after driving an LO3 5.0L with three cables attached to it and real springs, lol.
The best way to determine if there’s really something amiss or if it’s just subjective or if it’s simply the nature of the beast is to put a scan tool on it as Schurkey suggested and see exactly what the various readings are, preferably while driving it (carefully).
Start there and troubleshoot any system that is showing out-of-specification readings.
ruberbanman126
Apr 17, 2010 05:12 PM
daveward
Jul 27, 2004 06:08 PM
Ronn24
Jul 6, 2003 12:48 PM
LastViceRS
May 21, 2003 02:47 PM
chevyz73
Aug 14, 2002 08:49 PM
