Ultimate TBI Worth The Effort?
Old May 13, 2003 | 11:12 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Anyone who has done the Ultimate TBI mod on their car, I need opinions.
I recently installed headers and a catback on my LO3 as my sig shows. I'm now wondering whether to do the ultimate TBI on it soon. Is this going to make an appreciable difference in performance, given that my engine is internally stock, and staying that way for the forseeable future? Or is this one of those mods that one saves for the point when you've done everything else and you're trying to squeeze every last HP out of it?
Any input is appreciated.:hail:
Old May 14, 2003 | 03:23 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Old May 14, 2003 | 10:21 AM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i did the ultimate tbi mods on my 92 firebird i noticed a small diference in throttle response. nothing extreme but it was a bigger difference adding an open element filter and the adjustable fuel pressure regulator to it
Old May 14, 2003 | 10:34 AM
vjo90RS8's Avatar
Car: 2002 Z28
open element, tbi spacer, injection spacer, adjustable fuel pressure regulator, and modifying the TBI....all of those should give a noticeable power increase, not saying BIG, but noticeable.
Old May 14, 2003 | 11:50 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I noticed a way bigger improvement with an open element rather then the ultimate TB. with the ultimate TB mod i noticed a slight slight slight improvment in throttle responce
Old May 15, 2003 | 09:32 AM
James Montigny's Avatar
I gather from the responses that the "Ultimate TBI" mods are only marginally benificial at best
Has anyone dynoed this?
Old May 15, 2003 | 10:04 AM
deadtrend1's Avatar
they are worth a few tenths at the track, but they are free
Old May 15, 2003 | 01:22 PM
.3 seconds from that mod....
Old May 15, 2003 | 01:41 PM
From the porting/polishing or from the open element?
Old May 15, 2003 | 07:27 PM
steve8586iroc's Avatar
I went from a 11.0 to a 10.5 in the eigth. The only other mod was cutting the small end of the snorkel off my air cleaner assembly and running a new duct to the original scoop on the upper radiator support.
Steve
Old May 15, 2003 | 10:11 PM
Engine: LO3 and LT1
i noticed a small but noticeable difference. i went wild with mine though because i got the TBI for free and diddnt care all that much if i messed it up. but i ground the s*** out of it and then sanded it down to like 1200 grit .the hardest part about the whole project was grinding them damn bars that the throttle blades conect to they were really hard and took a long time if i can ever find out how to get my pics to show up on this board i will post mine
Old May 15, 2003 | 10:18 PM
LastViceRS's Avatar
Car: '91 RS
Well, no one's saying that it's an ineffective mod, and the price is right. Why not? Every little bit helps...
Thanks for the replies.
Old May 18, 2003 | 08:41 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
RED92BIRD305 what did you use to grind down the rods that the butterflys are bolted to i used a dremel at 35,000 rpm it took me probally 3 mins.
Old May 19, 2003 | 04:20 PM
Engine: LO3 and LT1
i used a high speed cutting bit it wasnt new so that might have been my problem
Old May 19, 2003 | 09:12 PM
Mike92RS's Avatar
To grind the shafts I used the rock looking bit, and it seemed to go through them pretty well.
- Mike
Old May 20, 2003 | 03:21 PM
Engine: LO3 and LT1
i wonder if the TPI throttle body would benefit from removing a little from the bars.
Old May 21, 2003 | 12:20 AM
rsilver's Avatar
When you ground the shafts what did you do about the t-rex bolts? Did you just grind the heads off of them too? If you do that, can you ever unbolt them again? ( I dont know why you would need to but who knows?) Also if you grind the bolts heads off, is there a problem with them loosening up over time and loosing the blades? I want to do this mod but I always wondered about this. Turbo city uses a modified screw when they grind the shafts.
Thanks for your thoughts..................bob
Old May 21, 2003 | 02:47 PM
Engine: LO3 and LT1
i left the screwheads on mine i just ground off the other side i wouldnt trust the blades with the heads ground off the screws
wigmobile
Feb 26, 2025 02:56 PM
Bubbajones_ya
Jul 6, 2024 08:32 PM
amcnellis
Sep 16, 2015 04:16 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
