new to forums
Old Jan 30, 2020 | 11:24 PM
damnchevy's Avatar
Car: 2006 nissan frontier
Engine: 4.0
Transmission: 4 spd auto
Axle/Gears: unknown
new to forums
i am here to pick brains and make you laugh. i have a 91 Silverado with a 350 tbi 4x4 that had two blown head gaskets. i changed the gaskets on top and am working on the bottom end. but now the truck is mine i will pull the engine and build it right. is it worth going stock? do these motor put out a lot of hp, or torque. i am not looking for a racer just a reliable engine. i will probably change the clutch and flywheel while i am in there.
Old Jan 31, 2020 | 09:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: new to forums
You might have better luck with a truck forum.
i think the k trucks 350 was rated 250-290 hp.
torque is decent with the swirl port heads. I don’t remember the spec from when I did a crate engine in my k1500 but I think tq is 300.
Old Jan 31, 2020 | 09:57 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: new to forums
You might not need to rebuild it if the bottom end is okay. These motors have a really long life. If you want it to be reliable, without having to DIY chip tune, I would keep it dead stock with the exception of a better exhaust and intake of some sort. Any internal mods (cam, heads, etc) to a TBI motor will require custom EPROM tuning.
BOTTLEDZ28
Sep 19, 2016 02:57 PM
macmatt
Apr 20, 2011 09:16 AM
shanep1991
Apr 5, 2011 01:14 PM
sparkplug619
May 21, 2010 09:55 AM
fordsuks91
Mar 29, 2004 04:49 PM
