Wire sliced?
Old Feb 1, 2020 | 01:52 PM
Kyler_89RS's Avatar
Car: 1989 Chevy Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi
Wire sliced?
I found this wire cut. Is this the wire to the MAF sensor?
Old Feb 1, 2020 | 02:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wire sliced?
That’s not a wire it’s a vacuum line
Old Feb 1, 2020 | 02:19 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Wire sliced?
I tried to plug it the other half with my finger but it didnt seem to affect anything at all. Didn’t even feel any suction.
Old Feb 1, 2020 | 03:48 PM
Drew's Avatar
Re: Wire sliced?
That's because the half of the broken line you're holding is the destination half, not the source half.
Old Feb 1, 2020 | 04:44 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wire sliced?
Emissions SMOG tag from an 89 RS:
Old Feb 1, 2020 | 06:25 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Wire sliced?
Yeah I meant the other half. The “source” half. I plugged it but it didnt do anything. No suction.
Old Feb 1, 2020 | 06:57 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Wire sliced?
Should I replace this line or should I be okay without it?
Old Feb 1, 2020 | 07:20 PM
Schurkey's Avatar
Re: Wire sliced?
You need it in winter, spring, fall--any time temperature is 45 degrees or colder. Easy enough to splice the broken section with two inches of vacuum hose. You can disconnect and plug in the summer. Or leave it connected all the time, the way GM intended.
Old Feb 1, 2020 | 07:32 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Wire sliced?
Makes sense. But what does the “vac motor” and “temp sensor” need this line for? If it isnt a potential fix to my starting problem, then I’m not gonna bother, so that’s why I’m so curious lol
Old Feb 2, 2020 | 01:50 AM
Drew's Avatar
Re: Wire sliced?
It's all part of the Thermac system and heat riser off the exhaust manifold. The idea is that when the temp is cold, heat off the exhaust manifold will rise and enter the intake and help the engine warm up. It's a remnant of the air cleaner that was designed to sit on top of a carburetor. On an EFI engine it's debatable if it helps at all. Plenty of people have dumped the entire air cleaner and not had a problem. If you want to fix it, it's easy enough to fix. If you don't want to fix it, just make sure the port on the throttlebody is plugged. Probably won't make any difference, but the beauty of it is you can try it and see for yourself very easily.
Old Feb 2, 2020 | 12:54 PM
Kyler_89RS's Avatar
Engine: 305 TBI
Re: Wire sliced?
Sounds good! Thanks for the info.
Old Feb 2, 2020 | 03:50 PM
Schurkey's Avatar
Re: Wire sliced?
The thermac prevents throttle icing; and improves fuel economy in cold weather. As I said, if you drive the car at ~45 degrees F or colder, you want it to work. The worst throttle icing happens around 40-ish degrees. The temp is cold enough that the temperature loss of fuel evaporation will put the throttle plates below freezing, but there's often lots of humidity in the air at 40 degrees. The humidity freezes on the throttle plates.
Adding hot air keeps the humidity from freezing, and improves fuel distribution with a cold engine or one that's got blocked or restricted exhaust flow through the heat-riser passages in the intake manifold.
The temperature is controlled by the thermostat in the air cleaner housing that opens or closes the vacuum supply to the air cleaner vacuum motor.
87camaro kid
May 29, 2009 02:33 PM
firebirdjosh
Jul 10, 2005 03:04 PM
89transam
Jun 12, 2003 04:16 PM
