Can I reuse stock valves?
Old Jan 13, 2002 | 02:25 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
They only have 8-9K miles on them. I want to reuse these when I buy new heads to save some $$ but if it's gonna mess up my whole operation I don't wanna fool with them.
Old Jan 13, 2002 | 03:12 PM
JPrevost's Avatar
Car: 91 Red Sled
They should be fine if they have low miles. Get them lapped for sure but if you don't have a 3 angle job get it done.
Old Jan 13, 2002 | 03:34 PM
Tas's Avatar
Tas
Unless they are back cut and or swirl polished or something else speical, might as well keep the valves that come with the new heads. What's your budget?
Old Jan 13, 2002 | 05:59 PM
NJ SPEEDER's Avatar
you can reuse tthe valves if they ar eth esame size. but make sure to get some lappiong compoound and set them in really good. it will help them to seal when they seat. you may wanna polish up the valves before you resue them. the new valves that come in the new heads aer prolly a higher duty than your stockers, they may last longer, but hat is up to you.
later
tim
Old Jan 13, 2002 | 06:51 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I was gonna buy the heads bare and use my current valves with new spring, retainers, and keepers. It's cheaper to do it what way. Almost $100/head cheaper after you add up all the other stuff.
The heads that come complete come with stainless valves. So yes they are stronger than my current valves.
Do you think a spring with 101# seat pressure will break them?
customblackbird
Aug 15, 2021 10:16 PM
gta90
Sep 15, 2015 04:00 PM
happyhapka
Aug 15, 2015 04:42 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
mustangman65_79
Aug 8, 2015 01:18 AM
