1982 corvette ecm harness terminals/pins
Car: 1982 corvette
Engine: 406 dart sbc
Transmission: 4l60e
Axle/Gears: 355
Does anyone have a suggestion on where I could find the terminals/pins for ecm harness ? thanks
Car: check
Engine: check
Transmission: check
Re: 1982 corvette ecm harness terminals/pins
Those terminals haven't been manufactured for a long time. Not sure if any can be had.
I do know that '80s to early '90s cars cruise control module harness connectors use the same terminals. May be able to fine some in the JY. But even those cars are becoming rare.
RBob.
RBob.
Car: 1982 corvette
Transmission: 4l60e
Axle/Gears: 355
installing ebl and noticed that u notched the ebl for the clips on factory harness to clear, and on the factory ecm the notches are opposite. meaning ill have to turn one of the factory connectors 180 degrees. wanted to make sure im installing correctly before I reconnect battery, and how careful do i need to be pushing connector on to hamm board (they seem to be very tight) and as tight as they are would you recommend using white ties around ebl after their connected just to be on the safe side not to work their way loose...
Thx for your help
Thx for your help
