Loss Of Function In 1 Of 2 Injectors
Old Apr 6, 2020 | 08:13 PM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
My apologies if this belonged in the DFI/ECM section... it's TBI Injector related.
Well this issue has gotten out of hand. Only one of two TBI Injectors fire under certain conditions. When the ECM is moved or adjusted the issue goes away (Loss of power while driving, tap the under dash pad where the ECM is and boom back to normal). Narrowed it down ckt 468 (green wire that splits between pins C15/D14) that controls injector # 2. Don't know if I should approach from the connector end and "re-seating" those pins or tracing backwards searching for a break in the wire.
Both approaches seem very, VERY challenging...
Old Apr 7, 2020 | 12:30 AM
Schurkey's Avatar
Re: Loss Of Power In 1 Of 2 Injectors
Let's be careful of terminology. Sounds like your injectors have POWER just like they should.
What they don't have is a consistent GROUND at the ECM for #2.
Whether you have a broken wire that has intermittent contact, a molded-connector pin that's out-of-position, or some internal fault in the ECM is yet to be determined.
Wild Guess: It'll be fairly apparent as soon as you expose the wire harness at/near the ECM.
Old Apr 7, 2020 | 07:24 PM
Engine: 305 / 350
Re: Loss Of Function In 1 Of 2 Injectors
I've had the ECM down, swapped ECM's, looked over the connector along with the 6in of wire from the connector back and nothing really stood out. No wires were noticeably loose, I'm at a loss. Any hints on where you'd start the troubleshooting?
Old Apr 7, 2020 | 07:53 PM
Schurkey's Avatar
I'd have expected a wire or connector fault near the ECM, as smacking the dash restores operation. Doesn't seem to me like it could be anything under the hood; or "far away" from where you're slapping the dash.
Wires broken inside the insulation? Used to be common on GM HEI pickup coils.
"Loose" terminals on the ends of the wire or in the plastic connector on the ECM? Intermittent contact?
Two faulty ECMs, both having failed the same way? Seems really unlikely.
That's all I got. Good luck, and "happy hunting".
Old Apr 7, 2020 | 07:54 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Have you looked at c207 ?
Old Apr 7, 2020 | 08:34 PM
Engine: 305 / 350
Old Apr 7, 2020 | 08:37 PM
Engine: 305 / 350
Wouldn't c207 kill both injectors at the same time?
Old Apr 7, 2020 | 08:40 PM
Engine: Lb9
Transmission: M20
G and b two different power wires
Old Apr 7, 2020 | 09:08 PM
Engine: 305 / 350
So on the G side that would be from the fuse block back to C100 all the way through the harness up to the injector I assume, where as I always wack the passenger side dash underside cover and it's back to normal. Heck I even drove with it rested on the floor for smooth operation... that is till it slid and boom issue returned. If I'm reading that right it's D14 that actually controls the injector correct?
Old Apr 7, 2020 | 09:18 PM
Engine: Lb9
Transmission: M20
Power from the fuse box to c207 to the injectors .
C207 is next to the ecm could have a bad connection.
Old Apr 8, 2020 | 11:11 AM
Engine: 305 / 350
Old Apr 8, 2020 | 11:12 AM
Engine: 305 / 350
Forgive my stupidity however those look like the actual connectors for the ECM... Didn't see anything like it next to the ECM.
Old Apr 8, 2020 | 12:39 PM
Engine: Lb9
Transmission: M20
Iirc it’s a clear plastic connector
Old Apr 8, 2020 | 04:14 PM
Engine: 305 / 350
This is what I have, If c207 is that offshoot, it was covered by that foam. If that's it... how do you suggest I check it?
Old Apr 8, 2020 | 04:46 PM
Engine: Lb9
Transmission: M20
Looks like the wires you need to look red and white.
table apart the connector and look at the terminals. Or run the car and wiggle the wires.
if failure occurs the engine will run rough.
Old Apr 8, 2020 | 05:42 PM
Engine: 305 / 350
Ran the car, wiggled, jiggled, moved and grooved the ECM, harnesses, and suspected wires... Issue didn't happen. This is going to be one of those hope it happens as I'm pulling up at home to catch it in the act situations. That is unless you can see individual injector status in TunerPro...
Also, would troubleshooting change if it only happens while driving? If so, any suggestions?
PurpleG20305TPI
Nov 30, 2012 11:55 AM
chevyracer8262
May 21, 2009 04:52 PM
FireDemonSiC
Sep 3, 2008 08:48 PM
4kidsandno$
Oct 17, 2006 08:43 PM
JPrevost
Nov 20, 2004 03:36 PM
