Camaro 305 TBI problems (new to this car)
Hi, i recently get one Camaro 305 TBI that was not driven about 6 or more years, so i am soon starting to work on this car. And of course i have problems. I was looking for similar things on forum and i didnt find one, so i am asking for help. I recorded problem so it can be easier to figure out. Thanks and sorry for bad english
https://youtu.be/wmiHcIvoGxE
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Camaro 305 TBI problems (new to this car)
Do you know if it ran when it was parked? See if the distributor is loose, or try retarding the ignition a tad to see if it calms the backfire. That would be turning it to the right a hair
Oh, and have you taken off the distributor cap to take a look?
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Watched the vid last night, slept on it... If it has sat undriven for 6yrs, I'd do a full tune up, verify ignition base timing, spark plug firing order and clean the IAC while rebuilding the TB. Good luck!
Hello, we did rebuild TBI and now it runs little bit better but still shuts down and sometimes blows fireball from TBI. I checked error codes, it gives 33 and 42. It also explodes from exhaust when is raving. Until i order new parts i wanna know, can it put 42 error code if timing is not right? In few days i will get equipment for checking that.
Thanks!
Thanks!
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: lt1 10 bolt 3.23
List of codes here:
https://www.thirdgen.org/forums/tech...l-gm-obd1.html
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
Check the vacuum hose going to it.
DTC - 42 Ignition bypass circuit errorGM FAULT CODE 42 ELECTRONIC SPARK TIMING(EST)CIRCUIT/FIXED
