305 TBI problems
Old Jan 3, 2021 | 01:52 PM
Rich89's Avatar
Car: 1989 formula
Engine: 305 for now
Transmission: Factory auto
305 TBI problems
I have a 1989 firebird formula 305 tbi, just bought it a few weeks ago not running. Code 54. I bypassed vats with the resistor. Fuel pump doesn't prime with key on but you can hear it run after turning the motor over. I have no spark, and no fuel out of the injectors. I have replaced icm, and coil, still no spark. Tested the pick up coil while cranking over and have no voltage. Swapped out computers as I had one here. I jump the fuel pump relay and the alternator buzzes, I ground out the green and white wire from the relay and fan turns on. Sorry this post is all over the place but I don't know what to do next other than possibly replace the distributor. Input please as I am.lost.
Old Jan 3, 2021 | 03:04 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 TBI problems
Since you didn’t have acv at the pu coil why haven’t you changed it ?
Old Jan 3, 2021 | 05:07 PM
Rich89's Avatar
Car: 1989 formula
Engine: 305 for now
I'm debating whether I change the pick up coil or just order a new distributor since I have to remove it and take it apart.
Old Jan 3, 2021 | 05:29 PM
Rich89's Avatar
Car: 1989 formula
Engine: 305 for now
Any chance someone here can tell me why I would have power at the tan and white wire in the fuel pump relay?
Old Jan 4, 2021 | 09:00 PM
Rich89's Avatar
Car: 1989 formula
Engine: 305 for now
Update, I replaced the distributor this evening and cars running great.
epsilonplus85
Jan 3, 2021 06:11 PM
charliemccraney
Mar 7, 2018 07:19 PM
NICK23
Jan 16, 2013 07:57 AM
martz0r
Apr 3, 2009 02:19 AM
chevyz71man
Jul 3, 2006 11:03 AM
