L03 Camshaft Fuel Pump Lobe??
Old Jan 27, 2021 | 08:41 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Does anyone know offhand if the L03 camshaft has a fuel pump lobe? I noticed my Lo3 did have the fuel pump provision and had the hole drilled also, was surprised and may try to run the engine in an old carved truck of my friends.
Old Jan 27, 2021 | 08:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: L03 Camshaft Fuel Pump Lobe??
I don’t believe the cam has a eccentric . You can always push in a pump rod and have someone manually rotate the engine and see if you feel movement.
Old Jan 29, 2021 | 05:27 AM
Drew's Avatar
It's been a few years, and aside from just my memory there's a bit of gray area, but I had a 305 TBI engine out of something... I think it was actually a Caprice/Cadillac/etc engine rather than from a thirdgen, but it went into a Chevy pickup with a mechanical pump and was fine. Not like it matters, you can get an electric pump to feed a carb at most parts stores for not a lot of money.
Old Jan 29, 2021 | 06:34 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Could go either way. The early ones built along side with the LG4 typically have the lobe. The later ones typically lack it.
A fuel pump lobe is just a 395' Marine cam swap away though.
91GTABird
Dec 19, 2019 06:23 PM
-LateNite89-
May 13, 2013 09:53 PM
Lee7
Aug 20, 2003 06:41 PM
