TBI from Holley
Old Jan 16, 2002 | 04:07 AM
ThirdGenFire's Avatar
Car: 2000 Trans Am and a 85 Iroc-Z
Engine: The Mighty LS1& 305 just beat meTPI
Transmission: 4L60E and 700R4
TBI from Holley
I was wondering, I want to buy that 670cfm TBI from Holley, but I heard that they don't hook up to the factory wires and so forth. Is this true because I want more cfm for my 350 and this seems like a great idea. Any info on this product would be appreciated.
Old Jan 16, 2002 | 05:15 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
It all plugged right in on my '88. I"ve got one with the GM injector tower on it, if you're interested in buying one. Drop me an e-mail if you are.
Old Jan 16, 2002 | 02:18 PM
JPrevost's Avatar
Car: 91 Red Sled
Everything bolts up and plugs in. Fuel lines fit the injector pod and the TPS sensor is only different for newer TBI units that have a 3 triangle instead of a 3 flat connector. That's still an easy fix since they holley uses the 3 flat you can grab any weatherpack from a junkyard TBI or TPI car/truck (from the TPS sensor). You have an 88 so it should just bolt right up.
Old Jan 16, 2002 | 04:14 PM
Thanks for the replies. I want to get it but I was not sure if it bolted up, I guess what I heard was wrong. Anyways thanks.
cowansauto
Apr 3, 2025 12:51 PM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Magman
Sep 14, 2015 01:30 AM
Glowsock
Sep 11, 2015 11:09 PM
