Latest combos
Old Jan 17, 2002 | 06:15 PM
fast_broker's Avatar
Latest combos
Combo 1:
E-Tec 200 heads
Holley 9901-107 MPFI manifold
Holley rail/reg kit for above manifold
28pph injectors
ProJection, then 7747 ECU control (if fails, get some other ECU)
Small TB then BIG TB units for air control only, no pods
OEM stainless Vette tube headers
2.5" dual exhaust, h-pipe, 2Chamber Flowmasters (too loud)
ZZ4 cam, 1.6 COMP magnum chromeoly rockers all around
Combo 2:
FastBurn heads
RPM AirGap Vortec manifold
2" TB unit with 90ph injectors at 15psi ish
exhaust not finalyzed, probably 2.5" y-pipe to 3" 3-chamber Flowmaster
zz4 cam with 1.6/1.5 crane golds (they sure put some bad springs in those Fastburns)
We'll se what happens.
Still no word on how/if the ProJection might run 8 high-imp MPFI injectors instead of two low-imp TB injectors... I guess I can blow one of my spare ProJection ECU's to try it...
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
1MeanZ
Dec 18, 2015 05:39 AM
roysatikas
Sep 22, 2015 08:15 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
