Inline fuel pump question
Old Jan 19, 2002 | 11:30 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Ive read that you can run a higher pressure inline fuel pump as long as your intake fuel pump is workin correctly... I was curious as to if I bought a Holley pump that worked at 45 psi if
1. the fuel lines can handle that
2. the intake fuel pump wont burn out really fast or something
3. I'll auctually be able to get 45 psi outa it incase I ever switch to mpfi...
Old Jan 21, 2002 | 07:10 PM
JPrevost's Avatar
Car: 91 Red Sled
The psi doesn't mean much. Just get the flow chart of the fuel pump. The 45psi just means that it can flow x amount of fuel under a 45psi condition. TBI runs much lower fuel pressure so expect the fuel pump to flow at least 20% more than what it does at 45psi. Sometimes the slope is even more but whatever it is it's always more flow when there is less pressure. The fuel lines can handle the 45psi of a mpfi but I would get new larger fuel lines if you go to TPI and start making some decent horsepower.
Old Jan 22, 2002 | 01:46 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Axle/Gears: 3.79
Interesting, thanks Jon! Next time Im at OSU I'll have to stop by... Id like to see what a fast RS looks like
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
