350 Injectors
Old Oct 7, 2023 | 08:24 PM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
350 Injectors
I am in the middle of rebuilding a TBI and doing the ultimate TBI mods. Has anyone used 350 injectors? Any tips, tricks, or issues to be aware of?
Old Oct 9, 2023 | 12:13 AM
Schurkey's Avatar
Re: 350 Injectors
Is there any actual evidence that the "ultimate TBI mods" do any good?
Strikes me as wasted effort, with the side effect of screwing-up the anti-corrosion plating of the throttle body.
Everyone with an OEM 350?
Get the fuel pressure "right" for your application.
Make sure the gasket surfaces are actually flat. The upper cover is especially susceptible to warpage.
Assure that the throttle shafts are not running on worn-out supports in the casting. (i.e., throttle shaft "bushings" wiped-out.)
Use the correct base gasket for your throttle body casting.
Pretty-much everyone who dicks with the base-idle screw later complains about idle problems.
Old Oct 9, 2023 | 05:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 350 Injectors
WOT MAP and 02 sensor readings showed it made a big improvement in airflow when I still ran small block TBI units. I had to add 1-2 psi fuel pressure to get the 02 reading back to where they were at WOT. I later compared a stock TBI unit to a 454 TBI unit on the same 3704 Edelbrock manifold that had been bored to 2" with a 2" oval open center spacer under the TBI units. The difference was 10 hp peak to peak and closer to 15 at higher rpm. 2-3 in/hg manifold vacuum went to less than 0.25 in/hg. The moded small block TBI dropped to less than 1 in/hg vacuum. That was a stock head, stock cam L05 with headers. Stock 305 air intake does pull a considerable vacuum at WOT, but a 14 x 3" open element with a flat base that eliminates the choke collar eliminates most of the restriction by itself. Removing the TBI ridges and adding a 1/4" spacer helps a bit more.
I ran 350 injectors in a 305 that had airflow improvements back in the day as well to feed the 305 enough fuel on the stock chip to keep it happy.
You can do all the stuff to the intake you want, but it is really the whole exhaust system from the head ports out that choke the power in stock form. The G-van L03s starting in about 1992 recieved the L05s 2.25" outlet manifolds, 3" Y-pipe and 3" single exhaust. They were net rated at 185 hp and that was with GM still using the restrictive pellet box cat. GM made 15 hp more than the F-cars using the flat tappet cams. The LG4 gained 5 hp when it recieved the roller cam with the same cam profile.
Old Oct 12, 2023 | 12:38 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: 350 Injectors
Old Oct 12, 2023 | 04:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 350 Injectors
This was before and after a 1/4" pod spacer and a stock bore TBI unit that had the rings trimmed off and radiused. Both runs had a 1" open center spacer and Edelbrock 3704 manifold bored to 2". 6 kpa increase in MAP. Stock heads and stock cam at the time. 454 TBI unit increased the MAP to 99 KPA which was almost barometric pressure. All 3 tests were also done with a 454 air cleaner assembly, K&N filter and a 454 air inlet duct. Stock TBI, no spacer and 350 air cleaner pulled down to 82 kpa. I had to increase the pressure and decrease the BPW and even later had to add more preasure because the injectors were static. Notice the injector pulse width is higher with the increased MAP. More airflow and thus more fuel demand. I also played around with maximum IAC opening for throttle follower as well. 255 counts at WOT vs 160 counts increased the MAP about 2 kpa by having the IAC wide open.
Kitttransam
Jul 10, 2023 04:19 PM
Tuned Performance
Feb 14, 2022 08:44 PM
Dstransam1
Sep 9, 2020 04:46 PM
Zuk1972
May 17, 2016 03:29 PM
yevgenievich
Apr 18, 2016 03:36 PM
