WinALDL Ver 1.06a released
Old Jan 22, 2002 | 10:53 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
Added a "Dash" dialog with a few variables in large numbers.
Old Jan 22, 2002 | 05:18 PM
JPrevost's Avatar
Car: 91 Red Sled
Cool, what exactly is this "Dash" stuff?
Did Ken every e-mail you again trying to see if you could edit the software to display the timing advance?
He said that he didn't think you understood exactly what we were trying to do. I tried just editing my eprom and it didn't display correctly. Since we replaced the battery voltage with timing advance the conversions were WAY off obviously.
I'd really appreciate it if you could e-mail me or somehow figure this out. Ken already found the data stream part that needed to be changed in the eprom. Now it's just a matter of displaying the higher bit value in place of the voltage.
Old Jan 22, 2002 | 06:26 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
The "dash" dialog looks like this:
It's so you can check these values at a glance, you don't have to find them in the table.
No, Ken did't mail me ... Why did you use the Bat variable? That is a one byte variable that is divided by 10. I think the spark advance is a two byte variable.
Why did you not replace the PROMID instead?
Then you could see the combined 16-bit value without any modification.
Old Jan 22, 2002 | 07:01 PM
fast_broker's Avatar
I'd like to get in on the "spark display" thing, if I could. Might help my progress.
JP, ever burn that spark curve I posted a while back?
Old Jan 22, 2002 | 07:14 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Good call on the Dash window.
A spark advance display would be cool.
Old Jan 23, 2002 | 02:03 AM
JPrevost's Avatar
Car: 91 Red Sled
FB, I tried the spark curve you gave and everything seemed fine but the fuel filter is so clogged again that I'm backfiring through the intake manifold again. This means no way for me to actually tell you if it's helping or not. There wasn't enough spark for at idle in gear. The car would stall every once in a while so I had to change that and give it more spark in the 40-50kpa 1800-2400rpm range. The stock timing tables seem to be the best for part throttle and cruising around town but yours seem better under harder acceloration. Again, fuel filter problems means I can't do anything until I either cough up $600 for a new tank or do something else. I'm going to change the fuel filter again and if it's bad consider my car parked for a LONG time .
Old Jan 23, 2002 | 02:51 AM
Jza's Avatar
Jza
lol. There's no link, but apparently, I have the address memorized by now.
Old Jan 23, 2002 | 05:23 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
http://winaldl.webhop.net
Old Jan 23, 2002 | 08:51 AM
20 degrees of spark at idle not enough for the 212/222 GMPP cam??? Something aint right there. That's enough. Maybe your VE table has too much variance around the idle area, ie, more than 2 VE units or so from map-to-map and rpm level to rpm level. That'll make it run terribly and not idle.
Old Jan 23, 2002 | 11:57 AM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Is it possible in the next revision to get the program so that it will automatically resize for the screen? My lapton screen is too small for it.
Thanks guys.
Also, is there anyone that is planning on releasing something to help understand the info a little better. I kind of understand it, but not really...
Thanks,
Mike
Old Jan 23, 2002 | 12:46 PM
JPrevost's Avatar
Car: 91 Red Sled
http://www.customefis.com/
This site has lots of info if you want to read about what things mean. Seems like a great guy. He supports winaldl AND sells cables etc. BTW, I too make cables and I'll beat his price since I'm still in school and need the cash!
Anyways, FB, yeah, the timing is way off. I also got some knock counts at low kpa values and high rpm. I have to make more adjustments and see why the near idle spark is so bad. It might be that my base timing is all screwy. This might be the case because I was running stock timing tables for a long time.
Old Jan 24, 2002 | 04:18 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
I can try and reduce the size some more. Do you use 640 X 480 ?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
