350 Tbi loading up at idle
Old Jun 17, 2024 | 11:13 PM
Zach Heitritter's Avatar
I have a 92 camaro 350 TBI ( Orig 305 ) Was my brothers old car and it had a 350 in it before, Badically just refreshed it.
Basically every sensor is new on it, CTS IAC, TPS, o2 sensor, New plugs wires distributor ect. When engine warms up and idles it will sound like it’s loading up, nearly dying and then rpm ramps up, It doesn’t seem like it’s losing power, I’ve triple checked the timing, Sometimes it dies at idle. I’m ripping my hair out on what to look at, It seems to have good fuel pressure, Used ether and a smoke machine and no vacuum leaks.
Old Jun 18, 2024 | 02:01 AM
Schurkey's Avatar
Re: 350 Tbi loading up at idle
"New" sensors do not have to be "functional" sensors, especially given the total junk coming from Communist China. There's a very real possibility that some or all of the "new" parts you just installed are not as good as the OEM ones you took off.
Did this vehicle get 350 injectors instead of the 305 injectors it came with? Are the F-body knock sensors different between 305 and 350 like the '88--'95 GMT400 trucks with TBI?
The Usual Three:
  1. Verify fuel pressure at prime, at idle, and under load. Most fuel pressure gauge assemblies have a push-button pressure release connected to crappy vinyl tubing. Route the tubing so it empties into a drain pan, then push the button while the engine is running. This simulates higher fuel demand if you can't check fuel pressure on the highway. Fuel pressure should remain steady even with fuel flowing down the pressure-relief tubing. How old is the fuel filter? Have you ever dumped a bottle of Chevron Techron Complete Fuel System Cleaner into the gas tank? (Recommended at every oil change.)
  2. How old are the usual “tune-up” parts and procedures? Inspect/replace distributor cap, rotor, plug wires, spark plugs. Make sure the ignition coil will reliably fire a spark-tester calibrated for HEI when the coil is fully warm, and misted with water from a squirt-bottle. Cranking compression test of all cylinders while the spark plugs are removed. Verify EGR, PCV, EVAP, and Heated Air Intake (if used) systems for proper operation. Verify proper initial timing and electronic spark advance. Replace old O2 sensors unless you can PROVE that they're working properly—old O2 sensors get lazy, they don't provide accurate data, but they do provide “data” that fools people into thinking they're “working”.
  3. Connect a scan tool (NOT a crappy “code reader”) and look for “codes”. More important, look at the data stream to verify EVERY sensor and computer output. Verify fuel trims during the time that the vehicle is not running properly. “Codes” have official diagnostic procedures that will be found in the service manual set for your vehicle.
DocByrum
Oct 12, 2023 02:13 AM
ryan thomas
Jan 24, 2016 05:05 PM
DD9TransAmGTA
Sep 22, 2014 12:33 PM
cboyd1
Dec 23, 2011 06:37 PM
Ward
Oct 13, 2009 02:52 AM
