350 Injectors
Old Jan 24, 2002 | 05:46 AM
91RS GUAM's Avatar
350 Injectors
Would a set of 350 injectors work with a stock throttle body, would I have to bump up the fuel pressure and if so to what?. what about the stock fuel pump would that still be good. I am still learning guys and appreciate all the experience and expertise here.
Old Jan 24, 2002 | 12:55 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, the 350 injectors will fit you stock throttle body.
what you bump your fuel pressure p to epends on the rest of your setup.
the stock fuel pump will also work with the new injectors.
hope this helps...
-brian
MustangBeater20
Oct 29, 2022 09:20 PM
bamaboy0323
Sep 3, 2015 06:07 AM
xxx3man`
Aug 28, 2015 02:21 PM
Keith5
Aug 27, 2015 04:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
