Help identifying part
Old Aug 1, 2025 | 08:03 PM
Bcmagoofan's Avatar
Hey guys this system that seems to runs from the gas tank to each cylinder and back to this box with two wires is smoking where it branches off to the right cylinder bay. Is this the pcv system? Will replacing the pcv potentially fix the issue? Where can I find the right pipes to replace my cracked smoking ones?
Old Aug 1, 2025 | 08:11 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help identifying part
It’s the air pump diverter valves, it forces air into the exhaust and not connected to the fuel tank at all.
Old Aug 1, 2025 | 08:56 PM
Bcmagoofan's Avatar
Awesome thanks for quick response! I guess exhaust smoke is supposed to flow through there and I just have a leak? Is there any parts I should replace besides the hose that is leaking?
Old Aug 1, 2025 | 08:59 PM
Engine: Lb9
Transmission: M20
Exhaust shouldn’t flow through the diverter valves or past the cheack valves on the manifold air pump pipes.
Old Aug 9, 2025 | 10:18 PM
Schurkey's Avatar
If you have exhaust smoke anywhere in the AIR system, you've got a failed check-valve at one or both exhaust manifolds, or rusted-through pipe between the exhaust manifold and the check-valve.
88TransAmGuy
Nov 8, 2013 10:43 PM
JunJun
Brakes
16
Jan 1, 2013 02:02 PM
bad to be blown
Oct 19, 2012 11:50 AM
TDIME479
Dec 15, 2011 02:29 PM
