remove vapor cylinder???
Old Oct 18, 2012 | 03:01 PM
bad to be blown's Avatar
Car: 89 gta
Engine: 5.7 supercharged
hi guys im totally revamping the engine bay on the gta hiding all the wires and welding all the holes up when i came cross a few probs with the vapor cylinder.
i have 2 lines running in to the cylinder one from the throttle body and the one that runs from the fuel tank. 1st problem the out line does run any where just comes out to a empty hoes??? 2nd problem is one of the wires has been snapped all along, not really a problem can soon be sorted.
so can u remove the the vapor cylinder? i have no EGR or SMOG on the car as we dont have the same test you guys have over here in england
thanks already guy
Old Oct 18, 2012 | 06:17 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: remove vapor cylinder???
You can but you need a vented fuel cap and need to rework the vent line ( that runs to the canister at front ) at the tank so it drops down into the breeze like old skool cars ( before pollution laws) ; you don't want fuel vapors venting to the engine bay
Redundant vac ports on TB need capping
Old Oct 19, 2012 | 11:50 AM
Car: 89 gta
first thanks for the help
so bin of the cylinder tapper of the wires, block of the port on the throttle body, bin of the hard line that runs back to the tank and have a line running from the tank under the car and a vented filler cap and jobs done???
thanks again
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
