New Heads/Engine Painting.
Old Jan 24, 2026 | 04:49 AM
Firebirds's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Transmission: World Class T-5
I recently took apart my engine(with it still in the car) and I repainted the intake manifold, valve covers, and when I get new heads I am considering painting those. Does anyone have any photos of similar projects or engine bay cleanups?
Edit: Also any tips on cleaning off the gunk from the pistons? I started this project because my valve seals were dust and I was blowing a bunch of smoke, and all of that ended up on the pistons and im having trouble getting it off. not sure what the risks are of taking a wire brush to them.
1991 Firebird 305 TBI
Old Jan 24, 2026 | 01:18 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: New Heads/Engine Painting.
once the engine is back together a fine mist of water from a squirt bottle is really all thats needed to clean the tops of the pistons..
but in reality, there is no need to clean them, a properly runnign engine will clean itself
Old Jan 24, 2026 | 01:25 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Oven cleaner works good on pistons-just make sure to get American made (easy off etc.) The discount import stuff is not as good. Your pistons look quite ok for an old car-at least the one visable. Use carb cleaner to blast debris out of the groove around the tapered edge of the pistons.A common cause of rusty coolant is oxygen getting into the cooling system from seepy head gaskets or cracked heads. Going back together,are you going to use steel shim or composite gaskets ?
Old Jan 24, 2026 | 05:57 PM
Firebirds's Avatar
Car: 1991 Firebird
Engine: 305 TBI
The one piston visible was the worst one, ill hit it with some carb cleaner or something like that before i put the heads back on, as for the gasket I havent ordered them yet, any specific recommedation?
Old Jan 26, 2026 | 05:34 AM
Firebirds's Avatar
Car: 1991 Firebird
Engine: 305 TBI
Bold of you to assume my engine is running properly
Old Feb 1, 2026 | 12:24 PM
gbeaird's Avatar
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Well, the compression may be running a bit low, especially on the driver's side.....
Swinnen25
Aug 23, 2021 09:17 PM
25thannivZ28
May 5, 2015 04:26 PM
firstfirebird
Jun 7, 2008 11:48 PM
chiefsmackahoe
Feb 26, 2007 06:43 AM
slowfast
Jul 7, 2006 01:16 PM
