Would Stock Vortec head springs work with an LT1 cam in a L03?
Old Jan 26, 2002 | 04:34 PM
raycer's Avatar
Car: 86 IROC
I was wondering if the springs that came stock on 350 Vortec heads will work when I install them and a LT1 cam this spring. Are they good enough? If not, what springs would be?
Old Jan 26, 2002 | 04:38 PM
Tas's Avatar
Tas
yes, but they're boarderline. There are some posts about K-motion springs. I think NTchrist has them.
Old Jan 26, 2002 | 09:08 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
k-motion makes springs thast will work just fine.. 42.99 is what they cost... lift up too .500 part number 571-k-700 in jegs ..
Old Jan 27, 2002 | 07:19 AM
DM91RS's Avatar
Car: 91 RS
I got the K-motion's too. With .480 lift working fine. Just be sure to check your retainer to seal clearance with what ever cam you install
Old Jan 27, 2002 | 04:56 PM
raycer's Avatar
Car: 86 IROC
So they will work but just barely? Hmm, guess I have to add another item to the list
As for retainer to seal clearance, how would I check that. It's a stock corvette LT1 cam with under 15K on it.
Old Jan 27, 2002 | 05:08 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Remember the vortecs will only hold .460 lift.
Brian
Old Jan 28, 2002 | 06:32 PM
raycer's Avatar
Car: 86 IROC
How much lift does an LT1 Cam have?
Old Jan 28, 2002 | 06:49 PM
Tas's Avatar
Tas
about .450 intake .450 exaust. Some of the later LT1 cams went up to around .460 exaust. That's all with 1.5 rockers. To find out lift with 1.6 rockers, divide the above by 1.5 and mulitply by 1.6
Old Jan 28, 2002 | 07:08 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I ran Vortecs with a .488 lift cam with no problems.
Old Jan 29, 2002 | 12:42 AM
HrdRockA4305's Avatar
I'm getting a set of Vortec springs off a freind of mine for free so I'm gonna have them put in when i get my leaky valve seals replaced. I think they'll handle my wussy LO3 cam just fine. Really whipped valve springs cause a major loss of top end don't they? Cause i'm REALLY bad when i'm much over 3300 RPMs or so, sometimes worse than others. Its a 128,000 mile engine thats had a hard life, figure might as well replace them with new ones since they're free. Couldn't hurt.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
