why does car take so long to start?
Old Feb 5, 2002 | 05:01 PM
sublime7880's Avatar
when i firtst start my car in the morning it takes a while for it to start up after cranking. i have heard from other people on the board that it has something to do with the fuel pump and the oil pump... the fuel pump wont turn on until the oil system gets presure? is this true? i have also heard that on tbi cars the oil pump uses the fuel pumps relay as a back up... any clarification on this will help!! thanks alot!!
1989 rs 305 tbi
flowmaster cat back
TBi mods
homemade ram air
hopefully much more to come.........
Old Feb 5, 2002 | 06:22 PM
Tas's Avatar
Tas
it could also be a vaccume leak or maybe your iginiton. Are your spark plugs dirty?
Old Feb 5, 2002 | 10:45 PM
TBI305Camaro's Avatar
give it a good tune up...my TBI hasnt even had the slightest trouble cranking over when its about 10 degrees outside...actually i think it likes it :rockon:
Old Feb 5, 2002 | 11:41 PM
JPrevost's Avatar
Car: 91 Red Sled
If it's just cranking over and over then try adjusting your base timing. Too much advance will make for a hard start and lost of cranking. The fuel pump oil pressure thing is ignored when first starting the car. The oil pressure switch is bypassed so the car will start but then it's directed through the oil pressure switch in a few seconds (not sure about that). Anyways, just turn your key to the on position and listen for the fuel pump. It should prime and start running for a few seconds to build pressure in the line even though no oil pressure is present!
Definatly give it a good tune up. Lots of mines = timing chain stretch and old plugs. I also recommend (if engine is hard just to turn over) that you replace the wires going to the starter solinoid from the battery. Sometimes these wires can get burnt from being so close to the exhaust.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
