View Poll Results: Intake swap with or without cam?
with cam, its not worth doing seperate
83.33%
without cam, lets see what happens
16.67%
Voters: 18. You may not vote on this poll
Should I try the intake swap without a cam?
Old Feb 4, 2002 | 12:17 AM
Tas's Avatar
Tas
http://www.holley.com/HiOctn/ProdLin...AMSM/7547.html
Should I try to put this on with headers and without a new cam to see what happens? I figure its SO much less work it couldn't hurt to try.
Old Feb 4, 2002 | 12:33 AM
Nate Hanson's Avatar
I'd do the cam swap all at the same time. I think you would notice the most gain, and the Lt1 cam will help you get into that rpm band a lot easier.
nate
Old Feb 4, 2002 | 03:28 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
its a win win situation. if you have the time and resources put the cam in
Old Feb 4, 2002 | 03:38 AM
Jza's Avatar
Jza
I would put both in at the same time, but looking at it from the other side of the argument: 1) if you do just the intake now and the cam later, you'll be able to attest to the individual gains from the intake and cam, and 2) the intake removal/install goes 3 times faster the second time around, so it won't be as big a pain in the *** when you DO the cam. With that said, I'll abstain from this poll.
Old Feb 4, 2002 | 10:16 AM
Keith5's Avatar
Car: C1500
If you already have the cam I think you should do it. If you have to buy the cam I think I would wait on the cam til I got a new motor. Yours did have high mileage right? It would also depend on how fast the miles are going on. If it's got like 150K but you only put 10K on a year, I'd probably do it then too. If the motor seems healthy and everything.
Old Feb 4, 2002 | 11:43 AM
Tas's Avatar
Tas
ya still waiting on a cam. 166K miles or so
Old Feb 4, 2002 | 03:58 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Taz, as much as Id love to see how much the cam will give on a stock top end, if you put that manifold on with stock cam/heads you'll pick up maybe .1 and you'll feel like you've wasted your time. Plus you're puttin headders on, so that'll skew your results. Drop the pan, take the timing cover (166k miles? eek, might wanna change that chain ) and pull that old cam (then do the traditional old part throw ... ohh almost a javalin effect with a cam...) and throw the new one in. You'll kick yourself if you dont.
Old Feb 5, 2002 | 07:17 PM
Tas's Avatar
Tas
ttt if anyone is bored
Old Feb 6, 2002 | 04:14 AM
Jza's Avatar
Jza
i'm bored. thanks.
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
