Ok TBI guys what spark plugs are u running?
What are you running and how do you like them? Right now I am running Bosch Platinums and I'm swapping them out cause I dont like them. I was thinking of going with AC Delcos but I want to get your guy's inputs.
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
im running accel shortys with msd 8.8, 90 degree boots.....i got tired of my headers having a cookout
if your running an msd box make sure you read the book that came with it it tells you what gap to run....i dont worry about temp range i just buy standard plug...or you can call msd they will tell ya what to gap it ......
if your running an msd box make sure you read the book that came with it it tells you what gap to run....i dont worry about temp range i just buy standard plug...or you can call msd they will tell ya what to gap it ...... Supreme Member
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
A/C Delco @ 0.045 gap w/ MSD Superconducter 8.5mm wires and MSD Blaster coil.
:lala:I have the MSD Cap/Rotor though too.
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Regular ole' AC Delco....hey, i've got a set of Bosch Platnums in a box never used if anyone wants to buy em for cheap. I really wasn't gonna even attempt to seel em, but they seem to be pretty popular among the TBI guys.
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I got the AC Delco rapid fires because they were only like $7 more than the normal ones from carparts.com. Eh, I'd rather have the money in my pocket. Ill use normal Delcos next time.
1992 Trans Am
May 10, 2023 07:19 PM
