My Open Element doesnt fit
Old Mar 13, 2002 | 05:31 PM
blue305rs's Avatar
Car: 1989 camaro RS
hey guys i tried to do a search but i came up without the info i need. Ok heres the deal, i bought an open air element the 14x3 and it did not fit right. It was the drop base. Am i supposed to get a new screw thing that goes in the middle because it was not tall enough for me to screw the top on. I know everyone says the flat base is better, so should i just order one of those instead? If so should i buy a longer screw so i can get the top on, or am i just doing something wrong? thanks for the help guys.
Old Mar 13, 2002 | 05:49 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
To use the drop base and the original air cleaner stud, you'll need to keep the spacer between the base and the throttle body.
-Rich-
Old Mar 13, 2002 | 05:52 PM
vjo90RS8's Avatar
Car: 2002 Z28
did u unscrew the stud as much as you can, it is adjustable, i didnt even know that until i went to kragen.
I installed a 14x3 flat based open element and the wing nut barely screws onto the stud, but i fits.
Old Mar 14, 2002 | 08:53 AM
TBI305Camaro's Avatar
get a NON-DROP base...i have a drop base and with the non-drop its much better...i had to unscrew the nut alittle but it fits fine
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
wruiz
Aug 13, 2015 09:07 PM
