Just Changed The Oil - Pics
Old Mar 13, 2002 | 09:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
well never has changing the oil taken this long. one more reason to not take it to a shop. i was in a hurry last time and knew of a hook-up so i took it to a shop and they decided the tighter the filter the better. this is how it looked after i got it off. i had to use 16" channel locks
Old Mar 13, 2002 | 10:15 PM
cobrakiller1989's Avatar
that is a jiffy lube filter, i suggest you do yourself a favor and never go there again. i had a honda in the shop with a jiffy lube filter on it. they cross threaded the drain plug in the aluminum oil pan and cost the guy almost $200 for a new pan instead of $20 for his oil change
Old Mar 13, 2002 | 10:29 PM
VIP car wash and lube in CC Texas. it cost 25 bux for the filter and oil ( Mobil One Full Synthetic) and a Mobil one full synthetic system flush. nope i have always done it myself it was a one time deal
Old Mar 14, 2002 | 12:29 AM
RSRagtop's Avatar
I had to look at that pic a for a while to realize what the f*** that pile of scrap used to be. Thats why I always change my own oil.
Old Mar 16, 2002 | 05:58 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i can never understand why the f*** shops put oil filters on so tight for........even fresh out of the factory......its very simple......hand on,hand off.........whats the f***in problem?
Old Mar 16, 2002 | 06:10 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I was in a hurry last time I changed my oil and I only grabbed a 1/2" drive. Dad had the adaptor to go on the bottom of the oil filter and so I just screwed it in with that real fast. I hope I didnt put it on too tight. Oh well, it'll come out.
Old Mar 16, 2002 | 09:26 PM
couldnt you use the oil filter socket to get it off
Old Mar 16, 2002 | 10:28 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
we used to get cars from jiffy lube after they changed it (and the customers never wanted to go back). When its that bad the easiest way to do it is with big ole' vice grips, if that doesn't work you take a long screwdriver, pound it through, and then turn, that'll get it every time...
-=-Mike
Old Mar 17, 2002 | 02:22 AM
deadtrend1's Avatar
Thats what I had to do once .... pound a 10" slotted screwdriver though cause the filter clamps i had sucked ....
on the Jiffy Lube saga. ......
Once my neighboor had a nice Datsun that he had tranny work done to it, and went the JL for oil change. The guy there comes out and starts explaining how the transmission fliud is a odd color and that it will need to be changed since it looks pretty old. MY neigboor asked to speak to a manager and flat out called his lie and made told them off. Pretty Funny .... Jiffy Lube is on my way to work and i usually see cars smoking so bad in the lot that it sometimes blinds the street.
~Tim
maroe624
Apr 16, 2017 08:29 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
