TOTW: Posi, Spools, and lockers, and limited slips...oh my!
#51
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Originally posted by Gunny Highway
Everybody is talking about 3.4X's gears.....what about 3.27's??? I'm looking for a good pick me up, but I'm very concerned about daily drivablity.
#53
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I lost a lot of my streetability with the 3.73's... its a big change from 2.73's. I suppose that I could have messed something up, but I really don't think so. I would increase all of the rpm's by a third, that would give you an idea...
I'm pretty blind right now, so I'm sure that I'll read this in the morning and probably correct myself...
-=-Mike
-=-Mike
#55
Car: 1989 Camaro RS
Just got back from the track, I wasn't doing too bad, but I was getting real bad wheel hop. whats the easiest way to correct that?
-=-Mike
-=-Mike
#56
Re: Re: PowerTrax Locker
Originally posted by AJ_92RS
I just put one in my car. I left the gearing alone for now. I'm in a trade union near Chicago so it's not unlikely that in 6 months I may have a job that puts 120 miles a day on my car.
Anyway, the PowerTrax is what I would say to be "serious ****" I never took into consideration that it's not a 'limited slip' rear end. It's kinda like a Detroit locker, without the air. The teeth are always locked, except when going through a turn. The difference in torque being applied to each wheel throught a turn is what unlocks the posi. But give it a little too much throttle and the inside tire chirps. It does this because it's trying to spin as fast as the outside wheel.
I've only had it in about 2 days now and I am slowly learning how to throttle out of turns to help avoid that. I'm sure I'll get the hang of it.
And I have tested it out. It takes a lot to get the tires to spin at all now with the 2.73, but I did get it to. It was weird riding out a 150' fishtail in my LO3, auto trans RS
AJ
AJ
#57
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
jegs has them
http://www.jegs.com/cgi-bin/ncommerc...708&prmenbr=76
#59
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: Re: Re: PowerTrax Locker
Originally posted by jordanz28ss
where did u get your powertrax no slip from? I just called summit and they said they don't make them for the 7.5/7.625 10 bolts anymore????
If you go to the www.powertrax.com website, they still show it being made
Maybe the guy at Summit has been around the Nitro too much?
AJ
#60
did it matter if it's a 7.5" or 7.625"
the guys at power trax are telling me that there is a differance between the 7.5" and 7.625".....I think mine is 7.625" it's an 88 camaro w/2.73 and 26 spline axles.
#61
Car: 82 camaro SC
Your car, if it's the original stuff, has 7.625 gears and 26 spline axles. Powertrax part number 1932 for the performance locker(from their website). 92-0776-2605 for the no-slip system. I got the performance locker way back when they first came out. I'd reccomend it to anybody that wants some serious traction.
#63
Car: '92 Rally Sport
Engine: LO3
-=-Mike
-=-Mike
#64
91RS5spd,
whats the web page to SLP so I can get there take off posi
#67
Originally posted by racereno
If you've got the money, I prefer the Air-Locker.
#68
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
I understand what you're saying. People just have to remember that they're not really made to run locked in street conditions. IMO it's like trying to run a spool as far as the everyday driving is concerned. Just run it open then when it's race time, lock it up.
#71
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hi guys - here's my dilemma:
I'm going to change my gears and rear end (I THINK). I was planning on going to a slp take-off posi with 3.73s but since i have a 1988 SC i would need 28 spline axles - correct? How much would the new axles cost - assuming I did the job myself. Also - with a 355 TBI set up with a cam for 2,000-6,000 rpm with an aftermarket intake, 670cfm holley unit, and head mods - would i be able to pull 3.73s through the entire 1/4 mile? Gearing is new to me lest you couldn't tell...
TP
TP
