If I slap a open element are fiter on my stock TBI are there any censors to be.......
Old Mar 18, 2002 | 11:36 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
If I slap a open element are fiter on my stock TBI are there any sensors to be.......
worried about? Last time I look I didnt see any but its better to be safe then sorry.
Old Mar 18, 2002 | 11:44 AM
Tas's Avatar
Tas
ya, you should relocate 1 sensor to a cool place, plug the vaccume line on the front of the tbi, and put a breather in the valve cover. 3/4" breather if I remember.
Old Mar 18, 2002 | 01:07 PM
Cant I designate a spot in the new air fiter for that sensor
Old Mar 18, 2002 | 02:08 PM
Tas's Avatar
Tas
ya you can but you might need to drill a new hole in it to fit. Depends what brand you get.
Old Mar 18, 2002 | 09:18 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Yup, he's right you can put the sensor back in the new cleaner unit. That's what I did with mine.
I bought a cheapy chrome cleaner and it had a little nub sticking out of it. I ripped it of with pliers because it was welded there.
Drilled the hole a tad bit bigger and the sensor snapped right in.
Mine has worked fine ever since with no problems at all.
I bought the non drop base type of cleaner and it came with a 2 1/2" element. Just bought a 2 1/4" K&N element for it and plan to put it in tonight.
By the way, if anyone is interested.........
The part number for that element is KNN-E-3740 if you shop at summit and it's part # 599-E-3740 if you shop at Jegs. They sell for just under $43 + shipping.
You won't find these numbers in their catalog, I've been looking for this for quite some time. I was at the Super Chevy show this past weekend and got the element from K&N direct. Yeah I paid more, but I got some nice goodies too.
Can't wait to see if I get a tiny gain from going from a crappy paper filter to a K&N.
I'll tell more once I get it in and see.
Old Mar 18, 2002 | 09:23 PM
TBI305Camaro's Avatar
i drilled a hole in the bottom of mine for the sensor...got lucky and it fit perfect and i screwed it in there...im running a 14x3 and it clears the stock hood with no problems. make sure you get a non-drop base or youll be sorry...i had a drop base and it sucked...hit the throttle linkage, had to use the spacer. not worth it. with the non drop you dont have to use the spacer ring, and it clears everything fine.
Old Mar 18, 2002 | 11:14 PM
HrdRockA4305's Avatar
My IAT sensor is inside my filter. Wasn't too hard to do, and I figured it'd be most accurate if its where its supposed to be.
Old Mar 19, 2002 | 02:55 PM
Snowdog 91 Formula's Avatar
Agreed
Drop base is a real pain to work around. I had a drop base for a few months. I got smart and bought a non-drop base, and took out that crappy spacer. Best thing I ever did, and it really makes things more accessible.
If you go non-drop, you might have to get a lower element or a higher hood for clearance.
I think the 2" would work great with no trouble. Still a good amound of air, and looks really clean.
I have the 3" element with non-drop plus a 1" TBI spacer, but my hood provides enough clearance for it all.
MustangBeater20
Oct 29, 2022 09:20 PM
86White_T/A305
Aug 17, 2015 12:16 AM
wruiz
Aug 13, 2015 09:07 PM
