can I harwire my winaldl wire in?
Old Mar 18, 2002 | 03:06 PM
dtpmike's Avatar
my serial wire I made for winaldl. I want to permanently wire it to the back of the car. I was wondering if I needed an on/off switch or if I could always run with it wired up but not plugged into a computer?
Also is there anything I can do so it reads the info faster?
Old Mar 18, 2002 | 03:52 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You can splice into the ALDL cables and have the interface connected at all times, no problem.
If you need the 10k resistor between the A and B terminals to get data you should put a switch on that.
You could also add another connector that is spliced into the ALDL cables. A stereo headphone plug will work just fine!
And it is not possible to make it read faster. Your ECM is 160 baud only.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
