How much pressure can stock 62 pph injectors take?
Old Mar 18, 2002 | 07:22 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
A friend of mine is putting a 383 in his Astro and were figuring out if he should buy 90 pph's or bump the fuel pressure up on the 62 pph's.
I figure the 62 pph's will need 22 psi to feed it.
Will they handle 22 psi?
Old Mar 18, 2002 | 10:50 PM
JPrevost's Avatar
Car: 91 Red Sled
They should handle it but for how long, I don't know. The more pressure the harder on the injectors and ecm but I think it's worth it since the spray is almost always better.
I'd stay around 15-18psi max, anymore and it's on borrowed time although many of the guys on the diy-efi lists have had great success with higher fuel pressure...just don't do it with the older style holley injectors!
MustangBeater20
Oct 29, 2022 09:20 PM
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
Brcharrelson
Aug 26, 2015 07:47 PM
ezobens
Aug 19, 2015 10:29 PM
