TBI fuel pressure check
When changing to an adjustable fuel pressure regulator, Where are you guys checking the pressure after an adjustment is made to see what you got?
Thanks in advance
95 C1500 350 TBI
Thanks in advance
95 C1500 350 TBI
Check the tech articles. The factory regulator is adjustible and there is an article that describes how. As for being able to test the presure afterwards I don't know. Just tweek it a little put it back together and test it until you find the best setting.
Car: 91 Red Sled
You can tap imbetween the flex lines. Some guys like to have it closer to the TB so they either spend $$$ for hardware and line or they spend 4 bucks on a pipe flare tube, 2 small hose clamps and a couple inchs of rubber line. There is nothing wrong with doing this since the pressure is well below 20psi in almost all cases of TBI tuning.
If you do get a guage, get one that reads from 0-30psi, not the carb version.
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i bought an inline t......i put it in in place of the fuel filter......screwed in the pressure gauge and did it that way.....when done just put the filter back in
92camaroJoe
Aug 13, 2015 06:07 AM
