AFPR or Vaccum FPR
Old Mar 22, 2002 | 12:16 PM
PopaPork's Avatar
AFPR or Vaccum FPR
What one is better for my car guys, and why?
Old Mar 22, 2002 | 04:23 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
Depends on what you are trying to do. With your mods, I wouldn't do either. Changing the pressure with a AFPR will obviously raise the pressure all the time and could create some rich conditions for you at lower RPMs. THe vAFPR is a way to get more fuel flow through the injectors to meet lean conditions on modified engines that the stock system just can't meet, primarily at high RPMs.
Hope that helps.
Old Mar 25, 2002 | 05:34 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
If you decide to use the vafpr, you will discover the spring supplied with it is too strong. The spring that came with your stock non-adjustable fpr is too weak. I have a replacement spring available for $5 including s&h. E-mail me if you want one. Lon
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Lmancha96
Sep 25, 2015 08:11 PM
rjcme
Sep 5, 2015 01:23 PM
Strick1
Sep 4, 2015 07:11 AM
