help AIR pump ticking like a sick case of valve lash!
Old Mar 23, 2002 | 02:02 AM
racereddy20's Avatar
is there anyway to completely remove the AIR pump unit (on the drivebelt) and bypass it with a pulley. I have AC on that side too and I dont want to cut that out (it works!). I live in a dry desert climate and the AC is a must! I thought about bypassing the AC for now (its only 80 degrees right now), but the summer is gonna kill me. I pulled all the air stuff out and the air pump on the drive belt is ticking so loud it sounds like a sick case of valve lash! HELP its getting annoying! please any suggestions will be appreciated.
Old Mar 23, 2002 | 02:15 AM
Jza's Avatar
Jza
You can pull it out and run a shorter belt. No need for an idler pulley. The tech articles section *should* have a diagram to show you the belt routing with A/C still connected. It's been a while since I've looked at it though.
Old Mar 23, 2002 | 02:28 AM
thanks man if you were a chick I'd kiss you right now. I just read it and saw the pics. It works!:hail:
backtothe80s
Sep 5, 2015 12:39 AM
redmaroz
Aug 16, 2015 11:40 PM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
mcquigg
Aug 13, 2015 02:26 PM
