ripping off smog 89 rs tbi v8
Old Mar 29, 2002 | 08:37 PM
89 red RS's Avatar
Has anyone taken the smog pump off of there tbi injected v8 and have any helpfull hints on it. like belt size i will need and maybe a pic of there before and after so i can see how they routed the belt. thank you, i kind off need the belt diagram now though because i can't seem to get mine to fit right it seems really tight.
Old Mar 29, 2002 | 08:49 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
https://www.thirdgen.org/newdesign/t...rpentine.shtml
make sure when you measure for your new belt you have the tensioner pulled back out of the way otherwise you wont get an accurate reading.........what i did is use a seamstress tape measure like they use to measure you for a suit? just wrap it around untill it overlaps itself subtract a half inch and theres your new belt size
Old Mar 29, 2002 | 08:57 PM
89 red RS's Avatar
thanks,
thanks for your help, plus i like your avatar, i wish i could get a custom avatar but you have to be a senior member or moderator right.
Old Mar 30, 2002 | 12:27 AM
deadtrend1's Avatar
Re: thanks,
i believe so .... i was a senior member when they were avaliable so I got it by default ...
~Tim
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Veaceonee
Sep 29, 2016 08:15 PM
racereese
Oct 10, 2015 09:39 PM
reactor60
Sep 22, 2015 01:44 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
