Open Element-Advance Timing
Old Apr 3, 2002 | 08:53 PM
L.I.N.Y.92CAMARO's Avatar
Since i just put an open element on my car should i advance the timing?, right now its set at 0 degrees.
Old Apr 3, 2002 | 10:23 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mine is at 4-5 and i have no problems that i know of. try it out see how the car responds.
Old Apr 3, 2002 | 10:31 PM
Yea, thats what i was thinking, about 4
Old Apr 3, 2002 | 11:23 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Remember to use higher octane gas (89 or 93) if u don't already or it will ping.
Old Apr 3, 2002 | 11:49 PM
NXS055's Avatar
hmm i might wanna check that then, cuz if i don't put 93 in mine she makes terrible noises, so maybe mine is already advanced... ill check it and see
would that do any good on an otherwise stock car? other than exhaust mods???
thanks
Old Apr 4, 2002 | 04:23 PM
NJ SPEEDER's Avatar
a little bit of base timing advance always helps. any car can benefit from it, especially a stock car with a stock chip in it. the stock timing tables are way too mild.
teh exhaust side of theengien has little to no effect on teh timing capabilities of the car. if you make mods to teh intaek side it can make a difference, butu for liitle things like ultimate mods and open elements it will be barely noticable.
like 91bird305 said, you shoudl run higher octane gas if you plan to advance the timing. i have seen some cars get as far as 6degrees when runnign 93 octane.
later
tim
Ghettobird52
Jul 5, 2024 11:18 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
wruiz
Aug 13, 2015 09:07 PM
