Changing my O2 sensor any tips?
Old Apr 4, 2002 | 08:39 PM
TEXAS89RS's Avatar
i will be changing the o2 sensor in my car, any tips that might make it easier? i know that there is a tool made especially for removing the o2 sensor is it worth it?
Old Apr 5, 2002 | 11:49 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Yes, go rent the O2 socket it'll make the job a lot easier. I rented the tool for free from autozone, I just gave them my credit card number and when I returned the socket they didn't charge my card. I had my O2 sensor out in about 30 seconds came out just like a spark plug. It was the original O2 sensor with 80000 miles on it.
Old Apr 5, 2002 | 02:02 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Don't try doing it 15 minutes after u have just drove ur car. I thought I would be cool and just not touch the headers or y-pipe when I was doing it....well my arm slipped and now I got a nice scare on my right arm from the burn. Oh well, its a battle wound!
EDIT: You knew that already (not to do it when its hot) but I had to tell my story. hehe
Old Apr 5, 2002 | 02:44 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Aucutally, I did mine when the manifold was warm/hot. The metal expands when its warm so it comes out easier. Just got the socket from autozone, nice long extension, and a wrachet. 5 minute job.
Old Apr 5, 2002 | 03:03 PM
JPrevost's Avatar
Car: 91 Red Sled
Cresent adjustable end wrench and anti-seeze. Never had a problem warm or cold.
Old Apr 5, 2002 | 07:32 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i got the o2 sensor changing kit from autozone. easy job w/ that
Old Apr 5, 2002 | 07:44 PM
fast_broker's Avatar
Yes, warm (not hot) and use a high-temp anti-seize (or make the anti-seize is on the one you buy, which it always is...)
Do not overtorque. go to washer contact, then 1/4 turn MAX more.
Old Apr 6, 2002 | 09:56 PM
TEXAS89RS's Avatar
thanks ya'll. rent the socket have and extention handy and make sure the engine is warm.
Old Apr 6, 2002 | 10:00 PM
TEXAS89RS's Avatar
oh by the way. i heard that the wiring harness connected to it is very sensitive is there a special caution i should take?
Old Apr 6, 2002 | 10:45 PM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
I changed mine a couple weeks ago. I waited until the car cooled down to reach in and unplug the connecter. Then I attempted loosening the sensor....no go. Then I decided I should go drive around to warm up the manifolds. I also thought it would be interesting to see how the car drove with the harness unplugged. Well, it was pretty normal, actually. I guess it just ran off the tables. I did eventually get an SES light, but not right away...I went back home and it came out with a little elbow grease.
db057
Jan 10, 2020 08:55 PM
HoosierinWA
Oct 7, 2015 10:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
