fuel injector wires
fuel injector wires
I replaced my ign. coil and the ecm fuse. Now my injectors dont spray any fuel. The fuel pump is providing fuel, but the damn injectors just wont squirt. I doubt both of them just died at the same time. Does anyone know how I can test if the wire is getting any juice, and where I can go from there? 2.8L
Before you do any of that make sure you've got good solid connections everywhere you were just messing with. On more than one occasion I had the plugs just slightly out of whack on the coil and they wouldn't fire.
Steve
Steve
tom,
I just had the same problem and it was driving me nuts!!!
Except my wires would not stick into the plastic that sits on top
of the injectors. So I would be driving and then the car would just
die, once I was trying to go home b/c of it and
the brakes would'nt work and the wheel wouldn't turn!!!!!!!
Try a voltmeter or check the connections,
if the wires are loose( u can tell if u can pull them out easily)
use some sealer on the outside of the plastic housing and let the
car sit for 2-3 hours. Then try to run it.
Firechicken86
Aug 12, 2015 10:07 PM
