compression test
Old Apr 12, 2002 | 06:53 PM
89formula4life's Avatar
compression test
does anyone know how many pounds of compressioneach cylinder supost to have in our LO3 engines i took mine today and got 180 pounds on the one cylinder i tryed... is this good?? thanks all....
Old Apr 13, 2002 | 01:24 PM
no-one on this board knows how many pounds each cylinder stock has??? come on now i know that somone here must know
Old Apr 22, 2002 | 05:52 PM
lugnut's Avatar
Car: 1970 chevelle
Engine: Lq4 408
Transmission: th400
Axle/Gears: 3:73
Thats plenty,as long as it doesnt vary any more than 10% from the highest to the lowest reading.Your on the high side for a fairly stock motor.Is the cam stock?That will effect compression.Somewhere between 150-180 should be normal.Have you checked them all?
Old Apr 22, 2002 | 05:59 PM
CamaroGuy71's Avatar
Car: 2002 TT Corvette
Engine: 5.7L
hes right. as long as they are all within 10% of each other they are fine. if u get readings like 160 for all of them and then 120 theres a problem. i believe anywhere around 120 should be good.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
