removeing air pump what size belt
Old Apr 12, 2002 | 10:35 PM
Dex's Avatar
Dex
I'm getting ready to remove the air pump what size serpentine belt do I need now I read the tech on it and I'm now more confussed
Old Apr 13, 2002 | 09:53 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
pull your tensioner out of the way,use a seamstress tape , the kind they use to measure you for a suit? run it exactly how it shows in the tech article,read the number where the tape overlaps itself , subtract 1/2" , your good to go
Old Apr 13, 2002 | 10:05 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i used a 930K6
Old Apr 13, 2002 | 11:55 AM
wasp's Avatar
yeah but its different for every application.......i removed my smog pump and put the same belt back on and it works fine........got me, depends how stretched the one your taking off is i think , not sure
Old Apr 13, 2002 | 02:35 PM
Dex's Avatar
Dex
So in short I'm gonna have to do some math to figure out what belt I need thats what I thought
The tech article need modified I was MORE confussed after i read it cause it says to run it a different way and in the picture with power steering its the same as mine is just no smog pump
WASP why does it say your on probation if you dont mind me asking and you have a bee as your little picture I liked your other picture:lala:
Old Apr 13, 2002 | 04:46 PM
deadtrend1's Avatar
when you remove the pump and re route the belts, you need one thats 2 inches longer usually. With 3 piece underdrive pulleys on my car heres the sizes.
With pump= 91.5" with pulleys | 94.5" without pulleys
without pump=93.5" with pulleys | 96.5"without pulleys
Old Apr 13, 2002 | 04:58 PM
deadtrend1's Avatar
heres how to route it. Like my 5 min schematic??
Old Apr 13, 2002 | 05:47 PM
wasp's Avatar
my other picture is why im on probation,religious people in texas are uptight , didnt ya know?
Old Apr 13, 2002 | 06:49 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
mine was what ever the tech article said, I ended up having to get one that was .1 longer, but the guy said it would be fine, he was right no problems
Old Apr 13, 2002 | 08:16 PM
wasp's Avatar
yeah i like the bolts on the pulleys too..........nice touch
Old Apr 13, 2002 | 08:48 PM
iroc22's Avatar
965k6 worked out quite nicely for me.
Old Apr 14, 2002 | 03:08 PM
Dex's Avatar
Dex
uuummmmmm my belt is already routed that way from the factory I just have an air pump in it So am I the only one like this??? I need a shorter belt not a longer one
backtothe80s
Sep 5, 2015 12:39 AM
mcquigg
Aug 13, 2015 02:26 PM
knight72
Aug 10, 2015 09:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
