TOTW: Intakes
Old Jul 7, 2003 | 01:05 PM
  #51
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
what about price of adapters?
Old Jan 10, 2004 | 09:32 PM
  #52
jobberone's Avatar
Car: 2001 F350 dlly; 89 6sp vette; 65 El Camino; 76 Cheyenne 4x4; 99 F450
Engine: 283; 307; 327; LT1; TPI; V10; 7.3; 400 SB .03 over
Transmission: 6sp; AT's; 5sp; PG
Right topic maybe wrong forum
Hi. New to forum. Actually don't have the car but I do have a 96 LT1 from a Z I'm thinking of running in a 65 El Camino.
What intake would you use if you went to a carb and got rid of the injection system. No boos here as this is not currently the way I'm thinking of going. What carb as well assuming stock heads and LT4 cam.
Also looking at boring out 283 to 4 inches and dropping in a 327 crank (forged) with reworked heads (202) and about 72 cc's with porting and polishing and 9.5 flat pistons. I have a torker I but I'm thinking better driver with a dual plane and wondered about a Stealth here. Some say the Torker is doable but you can read a newspaper thru the thing. Not sure this motor can take it. 600 Holley here BTW.
Last thought is bore 283 to 4 inches (old block can take it) and leave in 283 crank to make 302. Problem here is pump gas and need for better heads, bigger cam, pistons, rods yada. I wondered about a dual plane here esp with air gap vs the Torker I since much higher RPM here.
So your thoughts? Keep in mind I'm very new to all this and I don't know much.
Old Jan 10, 2004 | 10:39 PM
  #53
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Really what your concerned with are two things when switching to a carb. The first is the size of the carb and the second is that the cam will be able to pull enough vacuum to keep your brakes and stuff working. Generally with the size of the carb there is a formula that you can follow. I don't have it with me right now, but for an LT1 there is really no need to go beyond a 750 cfm. The LT1 is a 350 cubic inch block. Actually, if you could find a 600 or 650 cfm you'd be good. A lot of people will disagree with me and say go with a bigger carb, but it really doesn't work well. As for the vacuum you shouldn't have a problem with the hot cam but if you're concerned you could drop in a vacuum storage canister.
Good luck,
Mike
Old Jan 10, 2004 | 11:32 PM
  #54
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
Originally posted by pimpintheRS
i know this has been asked a million times but since its the topic of the week.. what do we have to do if we buy an intake without egr?? will the car run right or will it sputter.. do we need to have a custom chip burned and can we pass emmisions without the egr? lots of cheap carb intakes without egr... thanks
wow this is an oldie.
For Arizona, mostly Maricopa county, including some if not the rest of the state, require that you have an egr if your car came with one-most did, then you have ta have it, they will do a visual and they can still fail you on that, most of the testors dont know how they work so you can prolly get away witha "it looks like its attached, but its not really" approach alot of guys here will install the EGR and cats for smog tests then remove them as soon as their done.
Old Jan 10, 2004 | 11:47 PM
  #55
jobberone's Avatar
LT1 to Carb
Well still not certain which way to go yet. A lot of variables. Seems a waste to put a carb on that LT1 engine. I'm asking myself why not just put in a 350+SBC or BB.
The 327 is a good way as would be a crate like above.
As I said I have the Torker I and I believe it would be too much for a street engine esp even a 327. I wanted some opinions on not just engine but the engines contemplated with manifolds.
I gave too much info tho IMO so next time I'll just ask one question which is what manifold with the 327 with ~ .500 cam and 9-9.5:1 compression and 600 Holley. Is the Stealth ok?
Old Jan 11, 2004 | 12:01 AM
  #56
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
Originally posted by ShaneBuss
honestly, i couldnt tell a diff between the different single planes, but i could tell a difference between a single and dual.
Dont go spend a ton on the best single plane....
I'll be doing an intake swap soon and am planning on single plane. Its been a toss up between the TeamG and the X-cell. Money definitly an issue here. Does everyone seem to agree with him on this. The engine will likely never make over 300 hp.
Old Jan 11, 2004 | 12:50 AM
  #57
9c1Caprice's Avatar
Originally posted by darkhorse91
I might have missed it but, how much does a tbi adapter usually cost?
After I read this post the creative juices started flowing and I got an idea. A 1 1/2 plane intake! Take a dual plane and grind down the middle ridge halfway and sharpen it to a point. In theory it would produce more torque than a single plane and more hp than a dual plane. I don't know just an idea.
Also would a tbi adapter act as a tb spacer?
Thats exactly what I was thinking about.
Old May 5, 2004 | 10:38 PM
  #58
kennyg's Avatar
Hey, Ii'm running the Holley Street Dominator intake, wiht a q-jet, all on a GM Goodwrench 350 crate motor, the 260 horse one, thats 1299 in jeggs. What intake would work best, with the stock heads/cam, adn the 8.5:1 comperssion I currently have? Is my intake actually a good choice for the engine setup I currently have? What about if I wanted to swap to a torqier cam, will this intake still work good, or, if I swap carbs?
Old May 6, 2004 | 10:52 AM
  #59
Ronny's Avatar
WOW MUCHO POSTS. DID I MISS THE GM TBI VORTEC MANIFOLD ????? SOMEWHERE ALONG THE WAY I WAS INFORMED THE VORTEC HEADS WONT WORK SO I WENT EDEL RPM 11/2002) . VORTEC HEADS WITH THAT MANIFOLD SOUNDS INTERESTING
Old May 6, 2004 | 04:44 PM
  #60
Z28GEN3's Avatar
Engine: 305TBI
wow old thread!
I was thinking about the edelbrock torkerII single plane manifold, the only bad thing is it dont have any egr provisions. i guess since its not a PITA to swap manifods out i could get away w/o an egr and just swap the manifold out for smog.
Old Jun 18, 2004 | 11:54 PM
  #61
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
i have a holley strip dominator intake manifold laying around how would i find out the rpm ranges on it and the cfm and a good cam to match it and also if it will mate with my heads? is there a part number or anything i can look for cat onto it or something?????
Old Jun 22, 2004 | 12:44 PM
  #62
BigBadJap's Avatar
Car: 1989 GMC Jimmy Fullsize
Engine: 5.7L TBI (LO5)
Will swapping your intake force you to run a custom chip or will the stock ecm be able deal with the change reliably?
Old Jun 22, 2004 | 03:34 PM
  #63
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Chip work will get the most out of any mod you do but an intake swap will not cuase your car any problems with the stock tune. I would wait until you had a cam first.
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
