F'd Up ECM
Old Apr 14, 2002 | 08:21 AM
Buck268's Avatar
F'd Up ECM
OK, why, after I cut power to my ECM doesnt it clear the trouble codes out? I pull the fuse, and let it sit fer 30 sec. Doesnt clear codes. What I am not doing?? Also, I am getting a code 32 and 42. The 42 is an old code, and 32 (EGR Failure) is intermittent. Not a regular thing... Anyways, I just need to know why they arent clearing. Thank you!
Old Apr 14, 2002 | 09:15 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Depending on ambient air temp, it can take an ecm 10 mins to forget all it's codes.
Old Apr 14, 2002 | 09:17 AM
Buck268's Avatar
No ****? Thats wierd man. Oh well.... But all I need to do I cut power to it, right?
Old Apr 14, 2002 | 11:52 AM
JPrevost's Avatar
Car: 91 Red Sled
yeah, unplug the ecm fuse and let it sit while you grab a bight to eat
Old Apr 14, 2002 | 03:48 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
the capacitors in the ecm need time to discharge... Untill teh voltage bleeds off, the memory will still be set. try discharging everything by turning the ignition key like your going to start it (w/ the batt. disconected, of coarse)
Old Apr 14, 2002 | 05:59 PM
Jza's Avatar
Jza
Which ECM fuse are you pulling? The one in the fuse box is the 12v switched power source for the ECM. The one by the battery is the 12v constant source for the memory.
Old Apr 15, 2002 | 07:43 AM
Buck268's Avatar
Ah. That would explain something.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
