Timing Cover Installation Question
Old Apr 14, 2002 | 07:20 PM
ORAY777's Avatar
Is there an easy way to install the timing cover without having to drop the pan. Anyone done this before please drop me a note. Later.
Old Apr 14, 2002 | 07:29 PM
89BlueTA's Avatar
take out the first three bolts on each side and then loosen the rest until the pan will come down far enough, to get the timing cover on. Usually the oil pan gasket will reseal and not leak, but not always.
nick
Old Apr 15, 2002 | 04:14 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yeah, like he says: 'usually but not always"
I had to replace mine after a rather spectacular HB failure took a chunk out of it. It has a little tiny drip at the front seal that I have got tired of trying to stop. The front oil pan seal is a pain in the a$$, The only clean way to install the TC cover is to drop the oil pan entirely, which in our cars, requires pulling the motor.
Of course, it could be worse, we could have Fords
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
