Charging Problems
Old Apr 14, 2002 | 09:29 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Charging Problems
Whenever I let my car sit for about a week it's a little hard starting but once it does the voltage is low and the alternator squeels. It eventually goes away within a minute. The alternator is about 6months old and about 3 month old belts.
I was thinking I had a car alarm in the car, but it's no longer in use, but the red light that is lit from the alarm stays lit whenever the car isn't running. Could this small light over a week drain the battery causing me these problems?
Old Apr 14, 2002 | 09:44 PM
Jza's Avatar
Jza
It sounds like the alternator is on it's way out. Doesn't matter that it's 6 months old, if it's going, it's going. Don't get a reman.
Old Apr 14, 2002 | 10:39 PM
Car: 99 Formula
Axle/Gears: 342
It was brand new from summit 100 amp, it's fine anyother time , as long as the car is driven and not let sitting for a week.
Old Apr 14, 2002 | 11:13 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Sounds like there is a drain on your battery. When you start it up after a week, the alt has to work harder because it has to charge up the batt. The squeal is prolly the belt slipping because the alt is harder to turn when there is a large load placed on it. Check the belt to make sure it has the proper tension.
Old Apr 14, 2002 | 11:14 PM
Car: 99 Formula
Axle/Gears: 342
That's what I was thinking, eventhough the light from the alarm probably doesn't take that much power, I'm sure over a week it does drain the battery. The belt is tight also.
Old Apr 15, 2002 | 12:17 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I have a little light switch in the rear cargo area that gets turned on by accident sometimes when I take my tool box out. I don't even notice it until I'm driving along at night and see a little light in the rear view mirror. Anyway, that sort of drain adds up over a week.
Just a thought.
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Slush92RS
Sep 2, 2015 08:56 PM
greenyone
Sep 2, 2015 03:39 PM
