Just did a compression test and......
Old Apr 15, 2002 | 12:52 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Hey guys i just did a compression test on my 76 with a 400 and 6X heads heres what i got.
cyl. on driverside, front to back.
1. 184 psi.
2. 96
3. 184
4. 184
cly. on passengerside, front to back.
5. 184 psi.
6. 184
7. 96
8. 184
What does this mean? my car runs smooth but sounds but because of a header leak.
does this mean i have two bad cyls?
Old Apr 15, 2002 | 01:06 PM
SoCo80p's Avatar
yeah you've got 2 bad cyls, 3 and 7 are the most common to go south, it will run ok for a little while, but your not going to have near the power you would have if the cyl were fine, looks like its time to start saveing for a rebuilt, but first find where its leaking, could be a burnt valve, or crack in the gasket, get a cylinder leakdown test done then you will be forsure whats going on
Old Apr 15, 2002 | 02:01 PM
fiream's Avatar
Engine: 400HP 350
:mad:
here's the thing i just pick up the car, the owner said the motor has been rebuilt already. the only thing i can think of is he rebuilt everything except the heads, and just slaped the stock ones on. oh yeah the car was run with a header leak for awhile, could that be the cause?
Old Apr 15, 2002 | 04:59 PM
JAY87GTA's Avatar
yeah, if it's leaking on that side it could have burned an exhaust valve
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
